eclipsegsxer
- Apr 4, 2004
ypsilanti,
Michigan
ok i rebulit my cyl head on 91 gsx wnet back together fine.
now i get no fuel! checked voltage to fuel pump bracket seems to getting voltage. althought when i turn key on i dont hear pump kick in
this is driving me nuts... wat would cause this i get spark but no fuel
ground??? i even tried testing with the connector by firewal nothing
will fuel pump rewire fix this?
i swapped ecus, relay nothing i also tried swapping fuel pump brackets
checl for volts varried from 3-6 volts wtf?
