Boost pressure problem!!!!
1gGSXboostin
Mar 25, 2004
Mount Prospect, Illinois
OK, well I set the boost on my MBC at 14 lbs. "tested in 3rd gear". So when i go to get on the gas the boost will go up to 14 then drop down to about 10-11 psi and hold there. What is the problem. Am i leaking boost from the BOV. I had my manifold heat cracks welded. Need HELP!
