doodie
- 1,025
- 1
- Aug 11, 2002
Brooklyn,
New York
My Tail fuse keeps blowing out(the one that supplies power to the tail lights, parking lights, sidemarkers and interior light). I don't know what the hell can keep causing this. On the box it says it uses a 15amp fuse but when I first went to pull it out, it was using a 25amp fuse. Every single time I change it and when my car starts moving, the fuse blows. Its only that one that blows out. If I'm just standing there and not moving in or out of gear, the fuse doesn't short at all.
I noticed this started happening after we did the clutch/flywheel job. We rewired the FP and installed indiglos earlier but everything ran great for at least 400 miles before the clutch/flywheel job.
Can this be bad grounding? I did noticed that ever since I took off the negative terminal on the battery, the thing has been a lot looser but wouldn't everything else blow too?
