water pipe hose location?
FASTSPOOLINGST
598
Sep 17, 2003
Elizabethtown, Kentucky
On my water pipe there is a outlet in the left center of it pointing down at the ground. It's about 1.5 inches in diameter. Where does this hook up to? I bought a rolling chassis with a lot of stuff missing is why i am asking. If there is a link to a coolant hose diagram that would be great too. I will post a pic if necessary. I am going to be running a Full Garret setup too, so if it is unecessary and can be capped off, let me know. Thanks.
The water pipe that is back behind the turbo near the block goes needs a radiator hose on it and it connects to the lower part of the radiator. I hope that is what you are looking for.
Also, if you are going w/ a super big turbo you may need to dent that pipe in for the turbo to fit. I know the 1g's have a lot more room, but on 2g's they get smashed in all of the time.
no see the one in this picture that points down, underneath the mounting bracket. That is the one i'm talking about.
