game-hunter
- Jan 18, 2004
Lakewood,
Colorado
Hopefully somebody can tell me my 90GSX 6-bolt is not getting crankwalk. The car itself has over 200K miles on it but I just had the engine rebuilt less than 1000 miles ago. I had the shop assemble the rods, crank and head. I put the rest together but didn't double check the clearances on the crank. I also think it was making the knocking noise before the engine was rebuilt. I could be wrong though. The car is setup as follows.
1mm Oversized SS valves. 3-angle valve job.
8.5:1, .020 Ross Pistons
Eagle Rods.
ARP Main Studs
ARP Head Studs
Clevite Main Bearings
Clevite Rod Bearings
Cometic Head Gasket
Balance Shafts removed.
New style Lifters
Crower Springs and Titanium Retainers
New Timing belt/Tensioner/Pullys
New Water Pump
Fidanza Lightweight Flywheel
ACT 2600 Clutch with street disc.
OEM Throw out bearing
Prothane Motor Mounts
2G Ported Exhaust Manifold.
Just tested my compression last week, 160 across the board(~5600ft elevation). I just measured my crank movement using the following method. http://www.angelfire.com/pa4/awdcrankwalk/
I measured .26mm of play.
Here's a video of my car while I push the clutch in twice. The rpm's drop 100 whenever I push the clutch in. The engine was still a little cold when I took this video so rpm were approx. 1200.
http://www.kenjim.com/~james/clutchin.wmv
I currently have my warm Idle set to approx 880. If I set it to 750 my car likes to stall when I come to a stop.
Here's a video where you can hear the knocking sound. Almost sounds like the crankwalk.wav floating around. Sorry about the audio quality the vid was taken with my digi cam.
http://www.kenjim.com/~james/knock.wmv
I'm not really sure what to do besides drop my oil pan and inspect my crank and bearings.
Eagle Rods.
ARP Main Studs
ARP Head Studs
Cometic Head Gasket
New style Lifters
New Water Pump
