mitch83
- 141
- Mar 10, 2004
abilene,
Texas
Has anyone on here ever had a boost/vacum leak from their TPS. I have one and it's pretty bad. I tried to pump the system with my boost leak tester and I couldnt even get 1psi in it it would all just leak out at the tps is I wrapped in tape still leaked. I just ordered a new TPS in hopes that the old TPS housing was just wacked should air even be escaping in that area. I've read about TB shaft seals going bad as well is it located in that area. thanks in advance.
mitch
mitch
