92whitephantom
- 48
- 1
- Jul 9, 2002
ok guys i am going to try and explain this best i can to give u an idea what is happening
1st i just installed a 2g mas(all HC are still in), using the faq's for the wiring, all is right and no CEL comes on.
the car turns on but idles very rough, rpm's drop down to 500 and stay there until the fan kicks on.
also i tried logging the fuel trims and adjust them with the afc but i get nothing, the O2 trim stays locked as the others (LFT,MFT,HFT), once again the fans kicks on, then the O2 trims move(they show around 160). this has never happened before with my old blaha mas. also the logger shows the car to be running way to lean. LFT are pinned @ 140. no matter what i do with the afc they stay pinned. i have tried adding more fuel but problem still is there. it seems to get worse when i add fuel? i should also mention the afc showed to be getting plenty of air, air flow read about 56 on both afc and logger.
with the blaha it showed around 26 to 34 @ idle
then after being on for about 10 the cars shuts off, also when i press the gas i get no response, it sputters and dies
i also should mention i am running 450's if that helps and is causing my problem, also at the time of testing the 2g mas didn't have the filter attached
hope i explained it well enough and u guys get the idea of what is going on.the car is a 92
tsi awd
tsi awd
