problem with 1g intake
Turbo90Laser
33
Feb 17, 2004
wilmington, Delaware
i put in an after market air filter directly to the stock tube going to turbo i noticed a sensor on the stock air filter cover but didnt think much of it now my check engine light is on n the boost gauge wont work what should i do about the sensor or really what can i do if i dont want stock air filter box on n what to do about the sensor thank you
SO HOW WOULD I GO ABOUT PUTTING IN ANYTHING AFTER MARKET WHEN THE SENSOR IS IN THE AIR FILTER HOUSEING
Well, this is all first-grade DSM stuff, but:
1) You can cut the airbox off around the filter, leaving the sensor attached (you _need_ that).
2) You can put on an aftermarket filter, and an aftermarket pipe from the sensor to the turbo.
3) You can buy something like a GM-MAF Translator, and get rid of the stock airflow sensor, and replace it with a GM one somewhere else (but I'm willing to bet you'd have problems doing that, he he he)
-Jesse
