VexRacing
- 97
- Oct 17, 2003
janesville woo,
Ok Here is the problem. If car sits over night it wont start, unless you spray starter fluid in it. Than it will run fine. Now I have replaced the fuel pump, fuel filter, coolant temp sensor, cleaned the throttle body and sensors, cleaned fuel pressure regulator, and went thru the fuel delivery wiring. I need help with this thing bad.I am running out of patience and ideas. Thanks Vann
