Engine Update Pics!
SOURCE1064
954
Apr 15, 2002
Paramus, New Jersey
Enjoy she's coming along.
Engine Specs
Posted: Nov 30, 2005 11:44 PM
Engine
Racing Short Block Work
8 Hours of Port work
Extrude Honed
Balanced
Blueprinted
HKS Metal Head Gasket
Racing Head Work
Hot Tank
O ringed
Pressure Tested
Resurfaced
New Valve Stem Seals
Bronze Valve guides
Extrude Honed
J&E Forged Pistons 9.0:1 compression, .020" oversized
Eagle Forged Connecting Rods
Nitrite Coated Stainless Steel Valves 1.0mm oversized
Crower Titanium Valve Springs With Retainers
Clevite 77 rod bearings and main bearings
Buschur Racing Balance Shaft Eliminator Kit
Polished and Balanced Crankshaft
ARP Cylinder Head Studs
ARP Main Crankshaft Bolts
ARP Connecting Rod Bolts
AEM Adjustable Cam Gears
HKS Cams 272 degree intake and 272 degree exhaust cam1G Throttle
GReddy stainless steel mesh upper and lower radiator hoses
EVO External Oil Cooler Filter Mount
Forced Performance Vector Dampers under drive pulley
Dress Up Pulley Kit (water pump pulley, alternator pulley, and power steering pulley)
Concept Racing Race Crank Bearing Alignment kit
Concept Racing 4G63 Solid Lash Adjusters
Red powder coated valve cover with polished lettering
Custom spark plug cover with Japanese writing
Turbo
Forced Performance Red Turbo, Ported 8cm2 turbine housing, Clipped 10 degrees, and polished compressor housing
Tial Red Top 40mm High Pressure External Wastegate with 1.1bar spring
I'm probablly going to do a T4 setup soon. I just want to get this up and running.
Dang man, hasn't your car been down for like 2 years?? LOL Glad to see it's finally coming together.
Ditch that OEM heat shield and put a nice JM Fabrications polished one on there! :D
SOURCE1064 said:
Actually nearly 5. My car was done then I decided I might as well do the whole engine and all.
When do you think it'll be up and running? And don't jinx yourself!
Looks good bro, mine should be up and running soon too, but mine's only been down a year.
DSMJim said:
I remember you saying "wanna race" to me a long time ago when I made fun of the stickers on your car LOL.. I'm still waiting for that race :D
Still runnin the Auto Trans?
Just giving you time to tune your car Jim. :D
Still going to run the auto. I'll see how it is if I don't like it I'll do a stick conversion.
