95gst16g
- 614
- 3
- Nov 21, 2008
Clatskanie,
Oregon
Alright so a few days ago I was installing some cams on my 95.I got them all in and I was stupid I left the belt on the gears and I ended up breaking my cas because its behind the intake cam gear.So 3 days later nappa got me the 90.00 sensor.So I got the new sensor on and this time I took off the t belt and put the gear on.Well I go to start the car and noting happens.I have my timing wrong.I have tried to get it now 5 times using a wire type rod and rotating the motor until no.1 is at tdc but its not working for me.I'm finally just tired of messing with it.I dont feel like taking a bunch more crap off to set the oil pump and crank mark.I called a local shop and they told me they are not interested.I need this done asap it my dd.If anyone wants to do this for me I'll pay you I need my car.thank you
so I assumed you had done a 6bolt swap. Good luck man. I hope you figure it out soon and get your car back on the road.
.Thanks though
