Purging Nitrous
denniegst
292
3
Sep 13, 2004
san jose, California
i want to be able to purge co2 or no2 for show purposes only. i found these items and i was wondering if this will be all the assembles i need just to purge. thanks
9oz NITROUS BOTTLE, NITROUS TRIGGER, FEED LINE CLAMPS, 6FT.- FEED LINE, NITROUS NOZZLE, NITROUS FITTINGS, N20 REFILL ADAPTER
DUAL SHOT PURGE KIT
That is some cool looking hardware that you found! :thumb:
It looks like you are set up and ready to go...
I especially like the little bottle! That would be WAY too easy to hide in my passenger side airbag compartment... :cool:
I am guessing that if your purge is for 'show' that you plan to spray it out the top?
I went the 'other' way with my purge set up and have it spraying out underneath the car (for a little added stealth). ;)
Best of luck with your project!
Looks like you have everything you need.
I would use CO2 because of the cost (plus I have a 35lb tank to fill from) or maybe even propane but I'm sure there's some law against that. Propane would be super cheap tho. New 16oz bottle w/fill $3...
Anyway, I have one of those little CO2 bottles like in your pix, where did you get the valve for it???? I want to use it as an air source for filling tires off-road uc. And maybe adapt to a CO2 BB gun :shhh:
