stock ignition
ECLIPSE4x4
2,651
8
May 28, 2002
New Bern, North Carolina
When is the stock ignition just NOT enough. I am really new to tuning by myself and I am having some problems running boost levels about 20 PSI on my set up. I have decent O2's and egt's and at high RPM's at 20 or above PSI I get popping and knock. I am currently running accel 10mm wires and BPR7es plugs gapped to .028.
Seemed fine n the old BIG16G but now the door to tuning a bigger turbo is kicking my butt.
I would like to get input on when would be the time to upgrade to a after market ignition system like MSD.
thanx
I have seen 460whp on stock plug wires.
I think 520 is supposed to be the limit. Never heard anything about anyone having a problem with their ignition not being enough.
I would say go for it. The DIS2 I am making reference too. I just know that a nice crisp ignition can mean alot to the tuning key for people in the performance industry.
It is not like a small/big block but the timing ignition balance is still very well needed on any performance oriented car. I am running 20psi on my 20g with no problem, but every car has its own mind.
Good luck and give a review if you do this!
