2G Engine Degreasing
talon2gbuyer
1,118
2
Sep 24, 2009
Aston, Pennsylvania
Hey all, my engine bay needs a good scrub down. Its quite nasty looking in actuality. I have tried using degreasers on N/A cars before and know that you need to cover the alternator, battery, and valve cover breather so that water doesn't short out the engine components. Is there anything I should be aware of before I start doing this?
i did mine using simple green and a do it urself carwash.... never have had a problem... never covered anything... just stay away from filters and such
This. Simple green works great. Foaming tire shine gets everything all shiny also.
I second the 50/50 Purple Power and water. Spray it on, let it soak for a minute or two, hose it off and watch the nasty run down the driveway. I usually let the engine dry for an hour or so before trying to crank it over.
cool, good stuff :) I saw the purple power at the store, but have read that its really acidic and can cause more headaches than its worth LOL. So no one recommends covering anything? just keep the hood open and let it air dry for an hour?
I always covered the filter when powerwashing..
That degreeser in a can.Is not good at all..It seems to clean stuff, but it's based on petrolium..So it's leaves everything clean, just greesy.
The purple power is good stuff tho..And good ole, fashined windex, and paper towels, with elbow grease works too.
Purple power all the way, and if there is a really bad spot spray pure purple power on a rag an scrub it then rinse it off. I was amazed the first time I used it LOL.
Pressure washer is a must for engines. I would stay away from the alternator and air filter area. Had a bad experience in my other car with that. The eclipse needs a really good cleaning.
Really....don't cover anything? Not even the coil packs or anything? I been meaning to do this but thought I had take everything apart.
Just dont spend too much time soaking your connectors, I would stay away from starter and alt. with any kind of solvent but like simple green and purple power, I dont think they will hurt it if they were to get kinda sprayed.
Im going to cover the alt and breather/intake filters too just to be safe. Last thing i need is for my car to somehow short itself out because of some water. Ill go pick up some of the purple whatnot tomorrow. Thanks guys!
It isn't an acid at all, it is a strong base.
If you are worried about shorting the electrical out with water, just take the battery out until the bay is dry.
simple green in my preference. i ruined my hole engine bay paint with purple power and i kept it wet. i will never use that on a vehicle ever again. simple works great for me
You did something wrong. I've been using it for years on many many engine bays and haven't had a single bit of paint destroyed by it. I have even washed cars with it before. It's all about how well it is diluted.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
