does this prothane mount insert look right?
4g63and420a
140
Mar 22, 2008
white plains, Maryland
im workin on changing my motor mounts. i have the prothane urehthane kit. the lower mount, closest the radiator dont seem to fit right. or at least i think, ive beatin em with a hammer an put them in a press, an everything in between. is this how they are suppose to be? thanks for ya help
When i installed the one on my 95gst, i remember the front inserts were thinner than the rear and also had large washers that fit between the mtg bracket and mount. It looks like you could have the rear ones in the front.
The thick ones are for the rear ( left) and the thin ones are for the front (right)
i doubled check an i do have them in the right spots. the insert fits in good, it jus sticks out sum. i can push it into the braket so im gonna bolt it down an see ### happens, hopefully it will push the inserts in further.
Thats exzactly how my Prothane insert looked, my rears fit excellent. The fronts stuck out alittle till i got them bolted in. The only problem I had was getting the mount on block to slide down over the prothante but if you have two people it should be easy.
thanks man, at least i kno im not alone on this one. i was about to go check part numbers. im workin solo tonight but i can figure it out sum how. this talons seen more blood then a hungry bird of prey. my only mistake was to snach all 4 mounts out at once. the motors gotta gangsta lean. thanks all, i will post a pic once i get it in.
I only did the front and the rear, also if you take a bench vise that might help it together, but like i said, once you get the bolt into the mount, the insert won't go anywhere, becuase the mount will hold it in.
Here is the picture of my front mount with inserts and washers installed, easy fit, rear is the bear to install. My inserts were black not red from ES. Sorry for the bad pic very hard to take pictures in the pitch black :coy:
