Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 10-09-2008, 02:28 PM   #1 (permalink)
Temporarily Suspended
Region: Pacific Northwest
Classifieds Rating: (0)
Reputation: tsi1991awd is an unknown
Hard to start in the morning...what could it be?
91 Talon TSI AWD...it is hard to start in the morning. Its been cold here lately (WA) and it takes 3 or 4 times before the car starts. Then when it does start sometimes it'll stutter at a really low RPM before it starts warming up normal.
This is only on the first start of the day. Every other time it starts with no problems at all.
What could it be? I'm changing the spark plugs this weekend and the fuel filter next weekend. I have read the coolant temp sensor can cause it to have a hard start but this is only one time. It will start fine every other time. It idles fine, drives fine. Doesn't stall, die, etc. So I have no idea....
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 10-09-2008, 03:09 PM   #2 (permalink)
Proven Member
Region: Midwest
Reputation: interex is an unknown
I'm almost positive it's the spark plugs. Once you get them changed you should be good to go.
Online
Old 10-09-2008, 03:11 PM   #3 (permalink)
Proven Member
Region: Midwest
Reputation: Boost92awd is pretty helpful and trustworthy
Probally would hurt to go to autozone and have them check the battery and alternator.
Offline
Old 10-09-2008, 03:16 PM   #4 (permalink)
I'm buying the plugs after work today and going to put them in when I get home. BPR6ES....hopefully it takes care of the problem
Also, I should've mentioned that I just changed the alternator this past Saturday...was giving me the infamous glowing gauge lights. All better now though! Battery is only a year old but I checked it at Autozone before I did the alternator.
Offline
Old 10-09-2008, 03:24 PM   #5 (permalink)
Proven Member
Region: New England
Classifieds Rating: (2)
Reputation: talon187 is an unknown
I had the same problem it tuned out to be my coolant temp sensor the colder it got the harder it was to start the car
Offline
Old 10-09-2008, 03:29 PM   #6 (permalink)
Proven Member
Region: SoCal
Classifieds Rating: (1)
Reputation: 96mitsugsx is an unknown
CHeck your FPR. Maybe it's not holding pressure overnight.
Offline
Old 10-09-2008, 04:09 PM   #7 (permalink)
Quote:
How do I test it?
Offline
Old 10-09-2008, 04:24 PM   #8 (permalink)
DSMtuners Supporting Vendor
Road Race Engineering
Region: SoCal
Reputation: Sam@RRE is more helpful than not
the fpr only controls the fuel pressure while the car is running, its supposed to keep the pressure in the rail at a steady point at atmospheric pressure and lower pressure for every inhg and raise pressure for every psi. Has nothing to do with holding pressure over night. I second temp sensor. Check the connections on it, the car has two sensors on the housing, one single prong connector for the gauge cluster, and a two prong connector for the temp signal to the ecu. Seen the wiring fall apart, that's the most common problem.
____________________________
Sam C.
sam@roadraceengineering.com
Offline
Old 10-09-2008, 04:36 PM   #9 (permalink)
Quote:
I will check it later tonight when I do the sparkplugs. I just changed the radiator, thermostat and hoses this past Saturday and didn't notice anything. But then again I didn't look that good either.
What do I need to do if the wires are broken? Splice new wire? Is it the temp sensor itself that goes bad or is it the wires to the sensor?
Offline
Old 10-09-2008, 04:49 PM   #10 (permalink)
Proven Member
Region: Rocky Mountain
Reputation: Raptoreborn is an unknown
Quote:
I agree if it's not ignition. Check the coolant temp sensor.
Offline
Old 10-09-2008, 05:01 PM   #11 (permalink)
Proven Member
JayRolla's Avatar
Classifieds Rating: (6)
Reputation: JayRolla is extremely helpful and trustworthyJayRolla is extremely helpful and trustworthy
Coolant temp should through a CEL. Do you still have the fuel pressure return solenoid( I think thats what its called). Its a solenoid that helps keep fuel pressure after turning off the car. Usually people remove them. Only issue it causes the fuel system must prime every start.
Jason ~ 6bolt/4bolt E316G @ 30+psi, Corn Juice
Offline
Old 10-09-2008, 05:28 PM   #12 (permalink)
Proven Member
Region: Eastern Canada
Reputation: stefanOst is an unknown
When I had this problem it was a coolant temperature sensor like others have mentioned. Once the car would finally get started it would run fine, and start easy once warmed up. Would throw a CEL after running for a minute or two.
Offline
Old 10-09-2008, 05:36 PM   #13 (permalink)
Proven Member
r1991_4g63t's Avatar
Region: Midwest
Reputation: r1991_4g63t is more helpful than not
had this problem last winter when it would get under 20*. had someone tellin me to check the temp sensor but i wouldnt listen, after two weeks i took a multimeter and checked it, it was bad, basically telling the car it was 240* when it was 2* outside
Online
Old 10-09-2008, 06:58 PM   #14 (permalink)
Proven Member
Region: Midwest
Wow people just throw out weird suggestions. If the car turns over, it cant be the battery. If the coolant temp sensor goes out it will start but idle high on first start. :/
Online
Old 10-09-2008, 07:29 PM   #15 (permalink)
Proven Member
Region: Midwest
Quote:
you wanna bet? you obviously never had any training as a mechanic or you would know that when the computer sees the temp sensor at 240 it gives a different amount of fuel the it would if it was at 20, thus causing the no start when its 2* outside. a temp sensor, for the ecu not the guage, will absolutly cause a no start if its cold enough outside.
Online
Old 10-10-2008, 12:41 AM   #16 (permalink)
Replaced plugs, started strong...we'll see what happens in the morning.
Offline
Old 10-10-2008, 01:05 AM   #17 (permalink)
Proven Member
Region: Midwest
Sure, I've had a great amount of automotive mechanical experience... And I also just tested this theory by taking my water temp sensor out and 1st used a can of compressed air (upside down) to spray and chill the sensor, car fired right up but idled really high. Reset the ECU and then used my butane torch to heat it up, car fired right up and idled lower, reset it again and unpluged the sensor and the car fired up and threw a cel instantly. Hmm, Can't see where I was wrong when I made my previous statement.
Online
Old 10-10-2008, 01:58 AM   #18 (permalink)
Proven Member
BrokenTsi's Avatar
Region: Tri State
Classifieds Rating: (8)
Reputation: BrokenTsi is pretty helpful and trustworthy
I had a bad coolant temp sensor that would do this before. Sometimes the car wont want to start at all.
Online
Old 10-10-2008, 04:27 AM   #19 (permalink)
Proven Member
Region: Midwest
Quote:
DING DING DING we have a winner, thats what im trying to say, it wasnt everytime it started usually just first thing in the morning when its been sitting in -20* weather. i replaced the 2 wire coolant sensor and it fixed it
Online
Old 10-10-2008, 05:31 AM   #20 (permalink)
Proven Member
Region: Midwest
So, over night I sat my temp sensor in a little cup with water and put it in the deep freezer, froze solid. I just now went out and plugged it in while incased in the ice cube it froze inside of and tried to start the car. The car fired right up, and I checked and the tempature of the sensor and it was 4 degrees fahrenheit. Maybe my temp sensor is just not defective or maybe not "as worn" as others... But still never seen a car NOT start due to one missing, or malfunctioning. Maybe it depends on the car, the ecu, or the sensor itself. I'm the lucky one!
Online
Old 10-10-2008, 05:41 AM   #21 (permalink)
Proven Member
hdoerr's Avatar
Timeslip: 15.158 @ 92.190
Region: Gulf Coast
Reputation: hdoerr is an unknown
Our harness plug was loose inside the plastic. Maybe it just wasn't making a good connection. With out the temp sensor the ecu sees -54C and that richens the fuel so much that the car is hard to start or even run all together.
Offline
Old 10-10-2008, 05:55 AM   #22 (permalink)
Proven Member
Region: Midwest
I don't dis-believe that at all. I'm just saying I personally have not had that issue, or seen it happen around here. On my GM I know if I unplug the coolant temp sensor it just throws a CEL and lets the car start at a default stage.
Online
Old 10-10-2008, 05:56 AM <
