chris9149
- 91
- Jul 10, 2008
Lemoore,
California
Ok so I searched around a little and didn't find what I was looking for so I figured I would ask.
The quick question goes like this:
I want to know if the arm going from the intake side of the turbo to the exhaust side of the turbo controls the built in waste gate and if it does (I am pretty sure that is what it does) should I be able to move it by hand?
The longer story goes more like this, if you are interested:
I recently got a 1g talon and I am in the process of trying to clean it up and get it running right. I am doing all my maintenance right now (plugs, wires, filters, flush radiator, check belts...) and I have the radiator out while I had the system drained. am just cleaning up the dirt and grime that is covering everything in the engine bay so that I could spot any possible leaks and also to improve the aesthetics a little when I started looking at the turbo. I was checking out the arm that goes from the intake side of the turbo to the exhaust side (which is the internal waste gate control if I am not mistaken) and I noticed that it does not move. To my knowledge (which is limited) that should move back and forth to open and close the built in waste gate, right? If it is supposed to move I am thinking maybe that has something to do with why my boost is so high (at least it seems pretty high to me, 15psi).
Anyways any input on this would be appreciated.
Also, here is a picture of the arm in question, just in case I am not describing it well enough.
<a href="http://www.flickr.com/photos/chris9149/2721354824/" title="Turbo by chris9149, on Flickr"><img src="http://farm4.static.flickr.com/3200/2721354824_662e8714aa.jpg" width="500" height="375" alt="Turbo" /></a>
