Crazyjoker77
- 159
- 2
- Oct 9, 2004
Medicine Hat,
AB, Canada
okay so my new aem wideband came in the mail today and I'm gonna be installing it tomorrow morning. And would love a little bit of clarification on a couple of things.
I plan on running it in place of my rear o2 sensor in my catless Megan exhaust.
1. Since the original downstream o2 sensor is going to be removed i have to use the aem to feed the signal to the ecu correct? Now the instruction give 5 options for calibrating the gauge and i will just quote the instructions
"When set to P0 the gauge displays AFR values. P1 is the same as P0 but displays lambda.These settings implement a linear calibration with the most useful voltage range possible (0-5v). The AFR calibration P2 is linear and similar to P1 with a smaller voltage range (1-2v). The AFR calibration P3 emulates the Autronic wideband O2 sensor calibration(0-1v). The AFR calibration p4 emulates a non linear Nernst Cell calibration (0-1v)"
Now i believe i need to use P4 in order to use the white wire from the gauge to feed the rear O2 sensor pin on the ecu. (since the stock sensor is a nernst cell type and the ecu needs a 0-1v input) But will choosing this option affect in how the actual gauge reads out or is this option only affect the white aux out wire? Also when option p4 is chosen will the gauge display lambda or AFR?
Also any other tips for installing a EUGO in a 2g people could throw my way would be greatly appreciated as i know alot of people are running the gauge in this setup. As well does the seat need to be removed in order run the wire through the floor(i plan on using the stock rear o2 wiring route)
