Compression Test
JohnnyT
104
May 15, 2007
Sioux City, Iowa
I performed a compression test and got 119 on each cylinder and the car smokes when you hammer on it, am I screwed? I blew a turbo earlier, could it be the cause of the smoke? :laser:
No, I don't think it was warm, my dad did it since I am at college, I will redo it this weekend when I go home. What do I need to do to prepare for optimal results?
Yes, remove the MPI fuse thats on the positive battery cable and also disconnect the coil pack. You DO NOT want any fuel or spark happening during your compression test. Make sure the car is warm and keep your foot on the gas to keep it at WOT. Do a wet test, with a cap full of oil, if any cylinders have questionable results. Increased compression with oil indicates worn rings.
