turboblack2door
- 280
- Nov 11, 2007
ozark,
Missouri
i am showing 3 codes on my car
p0170 ( i replaced the front o2 sensor and made a rear o2 simulator)
p0446 it says EVAP condition cause 1.purge or vent solenoids defective 2.bad connector/wiring 3.fuel saturated vapor canister That is possible since the car was runnig so rich but where is it located so i can replace? 4. failed EVAP vent solenoidSame where is it located?
p1103 wastegate acuator issue. 1. open or short circuit condition.Where could that be? 2. poor electrical connection.Where could this be also 3. failed turbo wastgate actuator( boost is holding at 10lbs so it's not this)
