EagleTalonTim
- 830
- 13
- Jan 10, 2007
Brighton,
Tennessee
I have been fighting with this for about 2 weeks now and I am stumped. After doing a complete tune up including changing plugs, wires, fuel filter, air filter, O2 sensor and adjusting the timing, I still have major counts of knock up to 43 counts of knock just while cruising down the road. It only happens sometimes and that is what is confusing me.
Here is my setup :
NO BOOST LEAKS
JDM 6-Bolt
BPR6ES NGK plugs gapped at .28
Timing set at 5* BTDC
Stock fuel pump
Stock 13g turbo that comes on automatics
450 injectors with Manual Transmission ECU
Cyclone intake with flaps open all the time since I can't figure it out and can't afford to get extra parts to make it work.
K&N air filter with hacked can.
Nothing to tune with.
Everything else is stock.
I can't afford to go out and buy anything to tune with right now so I have to just get the settings right on my car now so I don't blow anything up.
Here is a log of a test drive that I did today : http://www.dsmtrend.com/tim/2008-03-23.html
Any help would greatly be appreciated!
Here is my setup :
NO BOOST LEAKS
JDM 6-Bolt
Stock fuel pump
