PCV solved ... Cheap!
94cyclone
73
Dec 19, 2007
rockford, Illinois
here is how I solved the whole leaky PCV thing:
I purchased a new fram unit from the parts store. It leaked, like they all do. Then I went to mitsu and purchased the hose that goes from the valve cover to the brake booster. The new version of this hose has a nice check valve built in. I cut it to length for my PCV system and walla!:sneaky:
I'm also confused. There are only two vaccuum lines on the VC: the breather to the intake pipe and the PCV valve line to the intake manifold.
Anyway, how does it idle? The PCV valve is a metering orifice. If the check valve restricts flow too much, that might make it idle rough.
Have you done a boost leak test to see if the check valve leaks at 20psi?
Might be a good cheap-o mod if it all checks out, though the check valves from USPlastics are pretty cheap.:thumb:
What "leaky PCV thing"? WTF
Why didn't you just pick up the Mits PCV while you were there?
So you used a brake booster check valve for a PCV valve?
My effing god. :toobad:
I'm a firm believer in the plastic check valves from USPlastic as the best solution, although I have yet to try them. I've purchased two new OEM Mitusbishi PCV valves and both of them leaked, although not as badly as the old wore out one of course.
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
