t-town_talon
- Dec 12, 2005
Tallahassee,
Florida
Well, my shifting has been hard for who knows how long. Feels like it wont go into gear easy, i dont really speed shift much but in the higher rpms its tougher to shift then just the casual shifting. On occasion, and i mean occasion, it will be smooth and no hisitation going from first to second. (stock clutch, b&m short throw). I figured id get off my @$$ and crawl under the dash to adjust the clutch pedal since it engages waaay too far off the floor, like...
- All the way out
- Friction Point
- To the floor
As i looked up, 12mm wrench in hand to adjust, i noticed a fairly big wet spot on the firewall/floorboard. My CMC is leaking, great, need to replace it. In the mean time i tried to loosen the nut (searched on here how to adjust), i got
"loosen the nut, turn rod, tighten nut. Then drive it and test, repeat if needed"
Ok so i tried to loosen the nut, the rod just turned with it. Nut never became loose. So i tightened it, rod turned too and it never seemed to tighten. Used vice grips to hold the rod, but it still turned.
Any help guys?
- All the way out
- Friction Point
- To the floor
Any help guys?
