| Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section. |
08-06-2002, 08:16 PM
#1 (permalink)
Proven Member
Region: Mid Atlantic
[RESOLVED] Timingbelt Falling Apart [Merged 8-8] groove cut short bolt bolts
Well, after putting some white-out on the tbelt where the groove is, after about 200 miles it gets worn away meaning whatever put that groove into the belt is still touching it. It took about 12k miles to get a groove worn about 1/8th of an inch deep. The steel threads are "just" starting to show through. Obviously its time to change the tbelt. I was just wondering if anyone has heard of anything like this. It has to be something barely touching the belt to make it worn like that. Theres never any smell and the groove is no hotter (from friction) than any other spot. Should I do a full tbelt change and replace EVERYTHING or just the belt itself since everything was done 12k ago?
Oh yeah, is there anything else performance wise that I should do while i'm in there?
Offline
08-06-2002, 08:22 PM
#2 (permalink)
Proven Member
Did you recently remove your oil pan? There are two short bolts that are supposed to go in front so they don't touch the timing belt. If you didn't put them in there, the incorrect "too long" bolts will wear a groove. Thats my guess without seeing a picture.
____________________________
-Matt
1990 Talon
Offline
08-06-2002, 08:27 PM
#3 (permalink)
Proven Member
That's one possibility... & the other is that the backing plate that seperates the Tbelt from the Bbelt was installed backwards. That & the problem listed above are the 2 most common causes of the groove worn in your Tbelt.
Indy Race Cores
Offline
08-06-2002, 08:43 PM
#4 (permalink)
Proven Member
i honestly wouldn't know the answer to either of those two questions, as I just bought the car a few weeks ago. The Bbelt plate being on backwards seems to me the most likely answer as whatever is grooving the belt is doing it hella slow, as if it were softer than metal. Thanks for the answers guys, now at least I have an idea of what to look for.
Offline
08-06-2002, 08:52 PM
#5 (permalink)
Proven Member
The more that I think about it.. it almost has to be the oil pan bolts to be a groove. The backing plate being backwards eats off the engine side of the belt.. not really a groove. Pull the 2 oil pan bolts directly under the crank sprocket.. I bet that one of them (at least) is longer than it's supposed to be.
Indy Race Cores
Offline
08-07-2002, 08:21 AM
#6 (permalink)
Proven Member
Yeah I'll do that today. I've never pulled any oil pan bolts before, am I going to get oil in my face taking off two of them? The groove is on the engine side, about a millimeter in and then a 1/4 inch wide groove that is about 1/8" deep. Either way, I gotta replace the belt, at least now I know what to look for.
Offline
08-07-2002, 09:23 AM
#7 (permalink)
Proven Member
Quote:
No. Unless the bottom of your engine is coated and it happens to drip on your face.
-Matt
1990 Talon
Offline
08-07-2002, 07:58 PM
#8 (permalink)
Proven Member
I pulled off the bolts on the belt side of the oil pan and none of them looked as if they were touching the belt. (they still had the seal gunk on them and weren't shiny as if from rubbing) I pulled two bolts from other parts of the pan and they were all the same size. they all looked pretty small so unless the ones by the belt are REALLY small, I doubt they are what is doing it. I'll let you guys know what I find once my replacement belt arrives and I make the change.
Offline
08-07-2002, 08:05 PM
#9 (permalink)
Proven Member
Sounds like the 2 shorter bolts are installed somewhere else in the pan.. ### the 2 under the crank sprocket are about 1/2 the size of the rest of them.
Indy Race Cores
Offline
07-19-2004, 01:29 PM
#10 (permalink)
Proven Member
Oil pan bolts under oil pump gear...
I just got done with the balance shaft emlimination kit...put the motor back in the car and somehow just came across this http://www.vallotton.com/engineremovalb.asp near the bottom it says that there are two bolts that are shorter than all the rest on the oil pan under the oil pump gear. It says if these arent installed where they came off the longer bolts will tear the timing belt. I went by the balance shaft elim on vfaq and had the chiltons manual handy and neither mentioned anything about this. Is this true? If so, I did not pay attention to the bolt lengths when reinstalling the oil pan. Can someone tell me what length those two bolts are? I will get some new ones to replace the other two. Thanks fellas...
TT
Offline
07-21-2004, 01:37 AM
#11 (permalink)
Proven Member
Region: Tri State
yes it is true. it will eat your timing belt. seen it in person.
Offline
07-21-2004, 08:22 AM
#12 (permalink)
Proven Member
ok...so I need two shorter bolts in there. Cool...thanks for responding.
Offline
10-18-2004, 10:41 PM
#13 (permalink)
Proven Member
Stripped Oil Pan Bolts
I stripped 7 or 8 of the oil pan bolts. My plan is to rethread them to 9mm, or whatever one size bigger than what they are is. My question is this, how would you go about fixing this? Is there an easier way?
Offline
10-18-2004, 10:50 PM
#14 (permalink)
Proven Member
Region: Midwest
how the hell? i dont have an answer, i think itll be hard to tap cast though..
Brian- 2006 KRP NHRA King of the Track champion
Offline
10-18-2004, 11:26 PM
#15 (permalink)
Proven Member
Region: Southwest
What about using a helicoil?
Offline
10-18-2004, 11:40 PM
#16 (permalink)
Proven Member
I'd use helicoil's, its not much more work than tapping it to a larger bolt and it keeps all the bolts the same size
Offline
10-19-2004, 12:18 AM
#17 (permalink)
Proven Member
Can I ask how you managed to strip those bolts?
Of all bolts those being around the oil pan and most likely covered with crap should come out EASY.
Seriously, not laughing but I'd really like to know how you did that. Please tell.
Offline
10-19-2004, 09:07 PM
#18 (permalink)
Proven Member
Ok well first off, I don't claim to be all-knowing or anything, I am still a beginner and am still making and learning from my mistakes. I think the best way to learn how to do something is get your hands dirty and do it yourself. So I tore my new JDM engine apart and am in the process of doing a rebuild. On that note, my grandpa's garage has every tool I could think of using, along with the ones I don't know how to use very well, and consequently I use them without "common" knowledge. I was using his small impact gun to put the oil pan bolts in. And before I realized what it was doing, I had already stripped a lot of them. Lesson learned, and it's not going to happen again. Now about fixing them with a helicoil, I don't know what a helicoil is. Can someone describe one? Or even better post a picture and possibly some info how to use one. I am gunna browse the net and see what I can come up with about them. Thanks a lot guys.
Offline
10-19-2004, 10:49 PM
#19 (permalink)
Proven Member
Quote:
helicoil kits from NAPA
thats where I got mine
Basically your making a big hole, then tapping it, next you insert what looks like a spring with the included tool. The inside of the "spring" should be the size you desire. Really it’s pretty easy as long as you can drill straight and make sure you use some sort of cutting compound on the tap.
Offline
10-22-2004, 12:39 PM
#20 (permalink)
Proven Member
Ahhh ok. Ya you shouldnt use an impact on bolts like that. Hell I dont even use an impact on lug nuts. Only place I really use them is on CV shafts.
Ok I just wondered. I had never heard of anyone breaking that many oil pan bolts.
That sucks. Also yes use the helicoils.
Just wondered.
Offline
10-23-2004, 01:39 PM
#21 (permalink)
Proven Member
Helicoil for sure
Offline
10-23-2004, 07:06 PM
#22 (permalink)
Proven Member
you used an impact to put ## oilpan bolts back in???
Eric
Offline
08-25-2005, 06:37 AM
#23 (permalink)
Proven Member
Reputation:  | |
