Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 01-06-2008, 08:31 PM   #1 (permalink)
Proven Member
iwannagofast89's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: iwannagofast89 is an unknown
Wheel stud stripped
I search and no one had the quite the same problem I have so hear it is....I was driving down the road and my right rear wheel strated to wabble and somewhere i lost 2 lug nuts. I tried to tight the remaining 3, but 2 of the 3 just keep spinning. So I'm thinking the wheel stud is stripped..Do any of you have any ideas I can get this fixed???
Offline
Related Auctions
Sponsored Links
Old 01-06-2008, 08:41 PM   #2 (permalink)
Proven Member
19Eclipse90's Avatar
Timeslip: 15.166 @ 98.270
Region: Midwest
Reputation: 19Eclipse90 is pretty helpful and trustworthy
Yes. You can replace the wheel studs.
____________________________
Brian
Offline
[posts] Reply With Quote
Old 01-06-2008, 08:47 PM   #3 (permalink)
Proven Member
Apeximprt2nr's Avatar
Region: Tri State
Classifieds Rating: (3)
Reputation: Apeximprt2nr is more helpful than not
Yeah, you just need to replace the wheel studs. You can replace them with OEM ones, or longer extended lugs for certain wheels.
-Jesse
EVO III, Fuel, Tuning, Suspension.
Offline
Old 01-06-2008, 08:48 PM   #4 (permalink)
Proven Member
Region: Midwest
Well I know how to do that I just don't know how to get the wheel off
Offline
Old 01-06-2008, 09:09 PM   #5 (permalink)
Proven Member
Region: Midwest
The lug nuts are still on the car and continuously spin with the wheel studs, not allowing you to get the wheel off?
Brian
Offline
Old 01-06-2008, 09:13 PM   #6 (permalink)
Proven Member
Region: Midwest
Reputation: awdtalon21 is an unknown
I had to drill through the lug nut and a little through the stud, and the lug should come off then.
Offline
Old 01-06-2008, 09:23 PM   #7 (permalink)
Proven Member
BUCK's Avatar
Region: Southeast
Reputation: BUCK is extremely helpful and trustworthyBUCK is extremely helpful and trustworthyBUCK is extremely helpful and trustworthy
Thumbs down
Quote:
You have stripped the spline on Stud where it mates to Hub - Been there - done this - & after I was done I replaced LOTS of Studs & Lugs & Anti-Siezed every damned one of them - Start off pulling OUT on tire & spinning Nut at same time - BE CAREFUL - Don't pull car off jack, etc.. - A jackstand would be better but you can pull one off a jackstand too - Once you get a gap try wedging a crowbar between wheel & Hub as you spin - & yeah an Impact was great help.
Offline
Old 01-06-2008, 09:36 PM   #8 (permalink)
Proven Member
Region: Midwest
Well i wish my bluepoint impact still worked oh well though I think ill be able to get it with that imformation thanks a lot
Offline
Old 01-07-2008, 05:47 AM   #9 (permalink)
Moderator
Car: Porsche Boxster S
Region: Mid Atlantic
Classifieds Rating: (1)
Just drill through the nuts. You'll need to replace the hub.
Ron
Offline
Old 01-07-2008, 06:31 AM   #10 (permalink)
Proven Member
Region: Midwest
How much do those run. I've onlt got 6 bucks and that Supposed to last me untill next Friday
Offline
Old 01-07-2008, 06:39 AM   #11 (permalink)
DSM Wiseman
turbosax2's Avatar
Region: Tri State
Classifieds Rating: (12)
A new hub is about $80-$100.
Eric
Offline
[posts] [blogs] Reply With Quote
Old 01-07-2008, 07:05 AM   #12 (permalink)
Proven Member
Region: Midwest
Holy sh&@ look like I won't get that for a while
Offline
Old 01-07-2008, 09:46 AM   #13 (permalink)
Proven Member
BUCK's Avatar
Region: Southeast
Thumbs up
Quote:
Actually my Hubs were fine & have been fine for years since - It was like the Stud was softer than the Hub - I just pulled new Studs in with Washers & NEW Lug Nuts coated with Anti-Sieze.
Offline
Old 01-07-2008, 09:50 AM   #14 (permalink)
Proven Member
Region: NorCal
Reputation: tqmx1 is more helpful than not
Are the studs turning in the hub or are the nuts spinning on the stud? If it is the latter use a high speed carbide cut off wheel and cut the head off the studs. If you are running steel wheels you could use a gas axe (kinda crude but quick ).
The new wheel studs are about $1.oo each at NAPA (had to replace one last friday).
Offline
Old 01-07-2008, 06:46 PM   #15 (permalink)
Proven Member
Region: Midwest
I think it the whole stud spinning
Offline
Old 01-07-2008, 08:50 PM   #16 (permalink)
Proven Member
Region: SoCal
Reputation: Mikael SS is an unknown
its possible you have the wrong lugnuts on the car. That's what happened to this guy
i can see it being hard to get them off
Offline
Old 01-07-2008, 09:50 PM   #17 (permalink)
Proven Member
Region: Midwest
dam that would sux. they are the same lugs that I got with the car over 5 months ago so they aren't the wrong ones
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stripped stud. what to do? whiteflash Newbie Forum 15 11-30-2007 05:05 PM
Stud holes on my head are stripped, what can I do? IllusionX90 Problem Diagnosis 1 10-17-2006 07:32 PM
Stripped wheel stud 98RedDragon Newbie Forum 10 07-20-2006 07:26 AM
stripped head stud holes sadsm Newbie Forum 4 06-21-2006 11:16 PM
Head/Mani stud stripped. How to fix??? 93jdmlaser Cylinder Head & Short Block 2 05-23-2005 09:44 PM
Page generated in 0.19621897 seconds (81.88% PHP - 18.12% MySQL) with 10 queries
