15 degrees outside. Cold start up problems
Matt4g63
191
Oct 25, 2007
Janesville, Wisconsin
Let me first start out saying that this is the coldest morning this engine has seen since being put into this car.
Today I went and started my car and let it warm up like usual when its cold. When I came out to go to class it was revving from 2-2.5k by itself. I revved the engine a few times and it didn't change anything.
I shut the car off for a little bit and came back out and it was acting normal, it had its normal get-to-temp high idle. But when I drove down the block it started to overheat.
I checked the coolant and it wasn't low at all. My fans still work also. I also do not have heat as of this morning. When I looked under the hood the first time I saw some leakage from the coolant cap.
Not sure what could cause a rough idle like that and cause me to not have heat when I still have coolant.
Thanks, Matt
Sounds like you heater core may have froze, did you check your coolant density? To much water and not enough antifreeze.
Well I know that I had an over heating problem this summer, but when i pressed the coolant hose and lets some come out onto the cement it was partially green. But I did ad alot of water to it this summer.
Besides a frozen core, you might have well froze it enough for a freeze plug to have partially popped out. Find the coolant leak first. Repair it, get a new thermostat and put that is and make sure your coolant is dense enough. The tester doesn't cost much at all. If in fact your coolant was frozen, i could see teh ECU forcing a lot of fuel and opening teh hell out of FIAV.
Well i just drove it around the block again, and left it running at idle while i checked the car for leaks, there were no leaks and the car didn't overheat?
  • For sale 1g 1G FWD rear suspension Drag lift setup
    This is for a 1G FWD. A drag suspension air lift kit. In the later 90s. Believe it was Dejon...
    • sanmantsi72
    • El_marto
