dont_blink
- Sep 1, 2007
Morgantown,
West Virginia
So I was out one day doing some WOT tunes at about 17-18psi on my 16G in my 1st gen. I was getting some crazy high rpm knock like 12-15 counts so I was trying to get timing reasonable. I finally did and decided to do a ~20psi tune. After a few runs my car started to feel like it was misfiring or bleeding off boost around 17psi/4800rpm. I brought the boost back down and changed the plugs. No change. Now I can hardly wind out first gear, it just feels dead. And in 2nd/3rd it will take me until like 4k before I get any serious spool. Then it feels like it misses hard when you have fouled plugs and I will get high knock counts and lose lots of boost/power. Mechanical timing is good, there are no boost leaks well to 25psi (DG BOV mod), the plugs are brand new gapped to .28, and brand new MSD wires. What I'm trying to figure out is what happened because something either broke or went screwy and now no matter what I do there is no fix. It just feels sluggish all around. Also the idle is all over the place. I had it dead set for 800 before this happend and now sometimes I'll idle at 1500 rpm or 400 rpm or 900 rpm and I even keep the gas on it sometimes when I push the clutch in to slow down or it will stall.
Could this be a bad CAS or ignition coil? Or...do you think my rings are shot and this is being caused by that?
I have some Link logs if any of you can read them.
thats crazy you'll blow something running like that.
Good luck, hope you find whatever it is. I think you're on the right track with something in the ignition though.
