dsmulla
- 200
- 1
- Jun 27, 2007
Scarborough,
Ok guys, I have been trying to fix this problem for the past week but I haven't gotten anywhere.
My car would only boost to about 10 psi and it would take a lot of effort to get there. I checked the wastegate arm and reconnected it to the turbo with some tension so it keeps the wastegate closed. I thought that would fix the problem but it didn't however, I do get boost around 3000rpm which is what my turbo is rated at and responds faster now. It still goes to about 10 psi though. Now I have tried doing a boost leak test but my boost gauge only reaches up -10 vaccum and it doesn't go higher.
What do you guys think could be causing the boost leak test to fail like that? Is it the wastegate flapper still open slightly?
P.S When I get on it, I can hear the leaks. I also tightned up all the couplers and I can still hear the leaks.
Thanks in advance,
Osman
Thanks in advance,
Osman
