Looking for a certain bushing
tsidrift1
819
5
May 12, 2004
Decatur, Illinois
I am needing the bushings that go between the rear subframe and the main frame. I have searched and searched and all I can find is about the sway bar bushings, track arm bushings etc. I would call them the rear subframe bushings. I just cant seem to find any info on where to get these.
Let me know,
Anthony
Look over this diagram and see if what you are looking for is on there. The one boxed in red may be what you are talking about, but I'm not sure. If you find it on the diagram, tell me the number from the diagram and I will be able to provide the Mitsubishi part number that should fit your Talon.
Mike
I think the one you circled is it. It should have one on each side right? Go ahead and get me, if you would, the mitsu part number for that.
Thanks A lot, you've been a big help
Anthony
Mitsubishi part number MB584140. The description given in CAPS is "Stopper, RR Susp Crossmember, Upr". The program lists needing a quantity of 2. I'm assuming one for each side.
Mike
If you want to go with an aftermarket upgrade while your that far into it (I definitely would with all the labor that is involved...), you might want to look here:
http://www.extremepsi.com/store/customer/home.php?cat=1005
Those bushings are probably part of the sub-frame kit, but you'll need to ask them to verify it, as their pictures are somewhat generic and non-descriptive of what each kit contains.
It's probably not much more expensive than OEM, if not actually less.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
