What should I get next? please answer fast!
90highpsitsi
31
Jun 19, 2007
Claremont, New Hampshire
Ok well Im wondering what i should buy next that is worth the money and make good power. My set up is this
57 trim garret turbo
tubular manifold
external waste gate
3 in. turbo back
jdm evo swap with 510cc injectors
fmic
safc (unhooked)
You need fuel mods ( ie pump, bigger injectors, fpr). A logger. Clutch, little odds and ends. Your post is very vague.
go with a water/methanol injection kit to reduce knock and increase your performance.
you can get a good kit from www.snowperformance.net
good luck and all i have seen from water/meth injection is good things and as mentioned very to no knock at all...
If you plan to keep your SAFC, get some 650ccs and a 190 fuel pump (or 255 and an AFPR).
I assume you have a logger already, since you have an SAFC.
No i dont have a logger and that is why my SAFC is unhooked. Bigger injectors is one thing i do need and one more question. How does the methanol injection work?
Quit putting stupid stuff like "please answer fast" in your titles when there's no reason for it.
the reason why was because i was trying to order parts that night. thanks for your strongly needed imput!
