fuel question
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
hey guys,ummm i want to upgrade my fuel system,i went to some shop to get some advices but im not sure that those guys are right. my question is do i need a 255 fuel pump and fuel pressure regulator on 550s injectors??? i got walboto 190 right now and i dunno what to do should a need 255 with the FPR or not thanks alot...
PS. Sorry if that question was somewere around here before,i tryed searching, but didnt came up with nuttin
Well you don't need the fuel pump to run the injectors, persay. You need the fuel pump for higher horsepower and airflow. The 190/550 combo will be fine, but I can't answer your question until you answer mine:
What horsepower are you looking for?
Knowing what your looking for is a must, also if do the 255lph you need a fpr to prevent flooding the injectors.
for now i want to get 350 whp with my setup that i have would be possible,cause im getting 550s for free from my buddy so 550s could handle 350? right??
Walboro 190lph
10psi = 46.48lbs/min
11psi = 45.89lbs/min
12psi = 45.26lbs/min
13psi = 44.58lbs/min
14psi = 43.86lbs/min
15psi = 43.09lbs/min
16psi = 42.28lbs/min
17psi = 41.43lbs/min
18psi = 40.54lbs/min
19psi = 39.60lbs/min
20psi = 38.62lbs/min
21psi = 37.60lbs/min
22psi = 36.53lbs/min
23psi = 35.42lbs/min
24psi = 34.26lbs/min
25psi = 33.06lbs/min
Walboro 190lph (Rewired)
10psi = 60.68lbs/min
11psi = 59.85lbs/min
12psi = 59.01lbs/min
13psi = 58.16lbs/min
14psi = 57.29lbs/min
15psi = 56.40lbs/min
16psi = 55.49lbs/min
17psi = 54.57lbs/min
18psi = 53.63lbs/min
19psi = 52.67lbs/min
20psi = 51.70lbs/min
21psi = 50.71lbs/min
22psi = 49.71lbs/min
23psi = 48.68lbs/min
24psi = 47.64lbs/min
25psi = 46.58lbs/min
Here's another helpful link
