pepsi21463
- 94
- 2
- Jul 16, 2005
Thornton,
Colorado
Well let me start off by telling you what happen in order of events. I was driving on the highway in 5th gear and did a little pull up to about 100mph..maybe 12psi on my GT3082r. My brand new motor has around 1,000 miles on it.
Well I heard kind of a loud pop, and the car got very sluggish. Then I saw the smoke comming out from under the hood and immediately through the vents. I immediately pulled over the car into a parking lot and popped the hood. Not really to my surprise the dipstick was sticking about 4 inches out and oil was all over the place. I called AAA and had the car towed home since I didn't have any cloths or extra oil.
Well today I turned the car on and revved the motor very slightly and heard a knocking noise, only under load. So I quickly checked my PCV and that was working fine, shut off the motor asap and did a compression test.
Going from right to left on the block the test read:
150-150-150-0
The last one never read anything and I tried two compression testers. I saw the piston moving and I felt air comming out of the spark plug hole. I know now I should try a leakdown test but is there anything else I could try, or look for?
150-150-150-0
