nwgtr
- Oct 9, 2006
toronto,
i have a 1992 eagle talon tsi awd
i tried searching but still a little bit confused about the plug wires.
i pulled one out and put it under a multimeter. set it to 200k range. shows 9.0 so i donno what range it's supposed to be. i didn't want to just go and replace everything if it's still good.
plus i read that firing order is 4123?
and the 92 doesn't have a cap right? it's direct? from the valve cover passenger side to the drivers side. it's supposed to be 4321 right? so i plug the wires labled 4 into 4 and 3 into 3, 2 into 2.....?
and the other end of the wire goes in what order? cus it's not 2 up and 2 down, it's more like a straight line or a little curve. so from the one that is closest to me would be 4, then 1, than2 than 3? is that how it works?
i donno if it's the wires or what that causes my problem. right now if i held my throttle half way it will have some boost, but as soon as it goes over .5 boost on the dash or if i floor it. the car just studders and doesn't want to go.
also when i start my car the headlights are on, is that the way it is supposed to be? when i twist the headlight switch from closed to on then high the headlight stays the same, i don't think that's normal right? if i pull the lever for high beam that works but if i just twist it all 3 settings are the same as my normal driving light.
