boost controller
x35 laro
Mar 28, 2006
albany, New York
when you put your boost controller on do you still leave the stock boost solenoid pluged in or take it out completely
^^ That was written with a 1g in mind. A 2g will likely throw a CEL for having the BCS electrical connector unplugged. The ECU likes to see that it's still there, even though the vacuum lines aren't connected.
To x35: Keep the BCS electrical connector plugged in. You can cap the nipples on it if you want.
And remember: don't tap the BOV vacuum line for your boost controller. :)
I use a Air compressor type boost controller, you can get them at Lows. On 2G's you will hook it up between your wastgate and the boost solenoid and cap off the other hole if you want. I like these ones for the reason you can push the cap down to lock it and you don't have to worry about it popping up. Turbonetics make one that looks just like it.
