97GsXfreak
- 137
- 1
- Nov 15, 2004
Berkeley Heights,
New Jersey
Having a problem with a 6 bolt in a 2g.. I have a RRE cas harness, I swapped pins in the ecu, and I also changed the firing order on the motor ( 4 with 3 and 2 with 1 ). I do have dsmlink and I chose the invert CAS when ordered. The car seems to not want to start.. DO I have to swap the 2 blue wires on harness to coil also, or is that done by changing the wires..
