T3/t04e
TopDowngst0803
30
Mar 30, 2006
Miami, Florida
Thats the turbo i got on my spyder eclipse, i was wondering ### injectors should i be running? I have 450cc's an i just know there not good enough for this big turbo.
depends on the boost level. you can run anywhere from 650cc-850cc injectors. You will have to get some kinda logger and AFC for tunning. i have an evo3 16g and im running 750cc injectors at 20 psi.
I agree just make sure u also have a walbro 255hp fuel pump with that set up of 660cc injectors
With a T3/04E 50 trim, 57 trim or 60 trim I would go with something larger than 660cc injectors. If you max the turbo out then you will need more fuel than the 660cc injectors can provide. In this case I would go with 880cc injectors (flowing 5 lbs/min of fuel at 43 psi base fuel pressure and .76 sg of fuel). If you do this you will need some sort of engine management beyond a SAFC (DSMLink, chip, etc).
With injectors this size you will definitely need a Walbro 255hp or a MKIV Supra pump, preferably with a rewire job and some sort of adjustable AFPR.
yea i have the 60trim and a walbro 255, im only running 6pounds right now though. Even at 6 pounds it feels like it needs more gas.
