I have a problem check it out
what would be the best solution since I will be removign the air can and replacing it with an intake.
A MBC is if your going to keeping modding the car.. a single line like "JayRolla" suggested or if dont want to buy the mbc
Your best bet would be to pick up a MBC. Easy to install and you will need one later on anyway.
You will use the vaccum lines from the BCS on your new MBC and you can unplug the BCS afterwards. One of the lines will go to your Jpipe and the other to your WG acutator.
i fix the problem, i went to a junky and replace the salenoid and works fine. i already order the MBC, than the intake will be order tomorow and the boost gauges. :)
Sounds good. When intsalling your boost gauge tie the end of the vaccum line to a close hanger or something sturdy, and shove it through the firewall. And there is tech articles on every other mod you purchased. Let us know what happens :thumb:
get an good boost guage too, make sure you tap into the best source. Try right off the intake manifold somewhere. And a word of advice try to use rubber hose for the boost guage insted of the crapy plastic stuff! it gets brittle and breaks.
good stuff guys! My car will be running good in no time, next stop 3'' catback exhaust :)
whatcha think?
-MBC
-Home made, intake haha. I just cut off the aircan in half and bought a K&n filter (it was free actually)
-boost gauge
Next stop 3'' catback exhaust.
If your not a high roller just go to a exhaust shop and have them make you a 3in exhaust, with a magnaflow muffler. Cheap and will sound good.
