mild_gst
- 52
- Sep 16, 2004
san antonio,
Texas
OK I dont know where to start. WTF I believe I have an electrical problem. I replaced my battery last week because my car died on me. I was embarrassed to see how much corrosion the battery had.
I brought new terminals but I didnt have wire cutters so I only replaced the negative side terminal. I want/need to get a ground wire kit, where can I price some? I looked in the parts catalog but I didnt find any links. I know HKS has one ($125) but I dont know if that price is a bit high or average. I'm also going to get some new spark plugs (NGK) and wires (MSD), should replacing all this fix my idle from fluctuating? It does this most of the time but I'm wondering if it's doing this because of the ground wires (all I did was clean them off). I also had the battery and alternator tested and they were fine so
what should I do? Yesterday as I warmed up my car, the stock temperature gauge fluctuated going up if that makes sense. It didnt raise smoothly. Another problem I'm having is with the clutch, it has little pressure. Also my cruise control doesn't work anymore. Can all this be connected somehow?
