Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 06-17-2002, 09:01 AM   #1 (permalink)
DSM Wiseman
Classifieds Rating: (2)
what fluids? [Merged 6-7]
i already got down what to use in my tranny, but what about the transfer case and diffs
Offline
Related Auctions
Sponsored Links
Old 06-17-2002, 04:46 PM   #2 (permalink)
Site General
Car: 01 Trans-AM WS6
Region: Southwest
Classifieds Rating: (4)
Redline Heavyweight Shockproof Gear oil.
Royal Purple 75-90W Gear oil.
Later,
____________________________
John-
Offline
Old 06-18-2002, 03:45 PM   #3 (permalink)
Proven Member
iceman21's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: iceman21 is an unknown
I have been using B+G Synchroshift since I bought my car and have been very happy with it.
Taken away the grinding and sloppiness
Offline
Old 06-20-2002, 08:47 AM   #4 (permalink)
Proven Member
Reputation: 1QWK4 is an unknown
You can use GM Synchromesh fluid in the tranny & T-case. I have been using it for years with positive results, reduced notchy shifting. You can pick it up at any GM dealership. Its the same thing as BG fluids.
Offline
Old 11-05-2002, 04:05 PM   #5 (permalink)
Proven Member
Reputation: GonePostal is an unknown
Question Recommended Transaxle Fluids?
What fluids do you recommend for the manual transmission, transfer case, and differential?
Offline
Old 11-05-2002, 05:43 PM   #6 (permalink)
Proven Member
Reputation: REDBLUR is an unknown
I used GM synchromesh for the tranny and transfer case, and the tranny shifted like butta. I recommend redline for the diff, with the same weight as manufacturers recommendations.
Offline
Old 11-05-2002, 08:04 PM   #7 (permalink)
DSM Wiseman
Region: Midwest
BG Syncroshift, Redline Shockproof, and Redline Shockproof
Eric Gash
Offline
Old 11-05-2002, 08:39 PM   #8 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (1)
Reputation: ImportModder is an unknown
I love GM synchromesh...
Offline
Old 11-06-2002, 04:38 PM   #9 (permalink)
Proven Member
Reputation: GsT916 is an unknown
GM synchromesh... it's works great
Offline
Old 11-07-2002, 06:29 AM   #10 (permalink)
Proven Member
Reputation: 99GSXturbo is an unknown
amsoil
Offline
Old 11-07-2002, 08:21 AM   #11 (permalink)
Proven Member
Reputation: 97GSTURBO is an unknown
Quote:
^ And Royal Purple gear oil!
Offline
Old 05-27-2003, 05:52 PM   #12 (permalink)
Proven Member
Region: Midwest
Reputation: 123bobby123 is more helpful than not
Changing Drivetrain fluids
Hi,
I have decided to change my transmission (5-speed) fluid, transfer case fluid, and read diff fluid soon.
To change the the transmission fluid, I park the car on a level surface, drain the fluid with the plug on the bottom of the trans, put drain plug back, open the fill plug, use a funnel with 1/2" O.D. plastic house to fill and fill until it starts to leak out, put fill plug back on.
I searched to find out how to do it for the transfer case and the rear diff, but I could not find anything on how to do it. How would you do it, like where are the plugs located and such, and deos anyone know the torque for these plugs, or is it just as tigh as I can get them.
Thanks a lot,
Bill
Offline
Old 05-27-2003, 07:45 PM   #13 (permalink)
Proven Member
Reputation: AfflictedPast is an unknown
Great info here. http://www.myzero.com/drivetrain/trannyoils.html
Offline
Old 05-27-2003, 09:23 PM   #14 (permalink)
Proven Member
Region: Midwest
Hi,
Thanks a lot. that is what I am looking for. Just a couple more questions, when I tighten the plugs back up, do I just make them as tight as I can, or is their a certain torque for each of them. Also when I refill the transfer case fluid do I drop it off the jacks to refill it or do I just refill it with the car up on the jacks. Anyway thanks for the great link, really appreciate it.
Thanks,
Bill
Offline
Old 05-28-2003, 07:16 AM   #15 (permalink)
Moderator
Defiant's Avatar
You should be level to refill it, but it really isn't crucial. A small bit of under/overfill won't matter. Tighten the plugs like someone else will have to remove them again with normal hand tools. Don't go wild.
Online
Old 05-28-2003, 01:58 PM   #16 (permalink)
Proven Member
Region: Midwest
Thanks a lot. So when I am doing the transfer case I jack it up drain it, and then lower it back down to fill it. How would I put the the fill plug back in, from the picture on the link above it looks like it is behind and under the oil pan. How would I get to it?
Thanks a lot,
Bill
Offline
Old 05-29-2003, 02:26 AM   #17 (permalink)
Moderator
Defiant's Avatar
If you jack it up from the front, the fluid will flow away from the filler hole.
Online
Old 07-07-2003, 08:32 AM   #18 (permalink)
Proven Member
Region: Midwest
Tranny, Transfer Case, and Rear Diff Fluids
Hi,
I am going to be upgrading my clutch to a ACT 2600, and during the install you have to drain the tranny fluid, so since I have been wanting to change all my fluids I figured I would od them all. I did some research and I am stuck on a couple of choices:
Tranny: 3 quarts of GM Synchroshift or Redline MT90
Transfer Case: 1 quart of Redline MT90
Rear Diff: 1 quart of Amsoil SAE 75W90 or Redline 75W90
I know they are all great products but I am not sure which would be best.
Thanks a lot,
Bill
Offline
Old 07-07-2003, 07:34 PM   #19 (permalink)
Proven Member
Reputation: damax03 is an unknown
I used the GM synchromesh in transfer and transmission, and then used a Mobil 1 Synthetic it the rear-end.
Offline
Old 07-07-2003, 08:03 PM   #20 (permalink)
Proven Member
HyperGSX's Avatar
Region: Midwest
Classifieds Rating: (9)
Reputation: HyperGSX is more helpful than not
I use Redline Shockproof for the rear diff. and x-fer case, gm syncroshift for tranny
Offline
Old 07-08-2003, 05:17 AM   #21 (permalink)
Moderator
Defiant's Avatar
Get Pennzoil Synchromesh instead of GM. Same part, 3/4 (or less) cost.
Online
Old 07-11-2003, 09:20 AM   #22 (permalink)
Proven Member
Region: Midwest
Thanks for the reply's
I will use Pennzoil Snychromesh in the tranny, Redline MT-90 in the transfer case, and Redline 75W90 in the rear diff.
Thanks a lot,
Bill
Offline
Old 07-16-2003, 05:52 AM   #23 (permalink)
Banned
Reputation: XxXEcLiPsE93 is an unknown
Question Question about fluids
ok i know GM Synchromesh and BG Synchroshift are the best fluids to use in the tranny....but what are the best fluids to use in the transfer case and rear differential?
im doing a fluid change soon and i wanna know what type to get
Offline
Old 07-16-2003, 08:02 AM   #24 (permalink)
Proven Member
Region: Midwest
Reputation: AW4G63 is more helpful than not
use REDLINE 75W90W for tranny and xfer case.
Rear end takes 90W I think, Check your owners manual , it says in the back.
Offline
