Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 05-01-2002, 08:18 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: Atari007 is an unknown
Question Intercooler Cleaning IC [Merged 11-7] clean smic fmic
I have read a lot about cleaning your intercooler... I was just wondering if any of you guys have done it, and can you feel a differance? I took a look at mine this morning and it does look pretty nasty...........
____________________________
Ash.
Offline
Related Auctions
Sponsored Links
Old 05-01-2002, 10:55 AM   #2 (permalink)
Proven Member
Reputation: fast_talon is an unknown
I cleaned my stock SMIC (when I still had one) and there was alot of oil resedue. It doesnt hurt to clean it out, considering any oil will cause resistance to the air flow. Did it make a drastic performance increase? I cant really say.. but its free!
Will..
Offline
Old 05-02-2002, 07:53 PM   #3 (permalink)
Proven Member
Reputation: apgeclipsegsx is an unknown
i took off my IC and pipes and flushed it all out with some degreaser and rubbing alcohol and let it sit over night. the i took out my dremel and spent a couple hours on the intake manifold elbow and turbo elbow, then i honed both pieces with my brake hone kit to make it all nice, made the turbo spool alot quicker
Offline
Old 08-15-2002, 07:04 AM   #4 (permalink)
Proven Member
Reputation: TsiRacer93 is an unknown
cleaning SMIC
how do you clean an intercooler, i was lookin at it the other day and its SOOO DIRTY.
Offline
[posts] Reply With Quote
Old 08-15-2002, 07:11 AM   #5 (permalink)
Proven Member
Reputation: dsmnate is more helpful than not
Here is a link.....
Cleaning your Intercooler
-Nate
-Nate
Offline
Old 08-15-2002, 01:17 PM   #6 (permalink)
Proven Member
RedTurboEclipse's Avatar
Region: NorCal
Classifieds Rating: (16)
Reputation: RedTurboEclipse is extremely helpful and trustworthyRedTurboEclipse is extremely helpful and trustworthyRedTurboEclipse is extremely helpful and trustworthy
i cleaned mine.. it was pretty dirty.. but wen your removing it.. you might not see one of the top screws that is holding the SMIC.. what i did was take out the sidemarker.. and you can see the bolt from there.. then i used a ractchet from the air duct.. stuck my whole hand in there to reach it.. it was a biatch to take off.. so i didnt put it back on
and i used little amounts of paint thinner.. shake it a lil.. and then ran water through it.. did the job.. now its super clean.. good luck..
1998 GS-T (Sold)
1995 GSX x2
Offline
Old 08-15-2002, 01:42 PM   #7 (permalink)
Proven Member
Reputation: dsmtrick is an unknown
Gasoline works too.
Offline
Old 08-15-2002, 02:05 PM   #8 (permalink)
DSM Wiseman
Classifieds Rating: (2)
Yes gasoline, acetone, paint thinner or just alcohol
Austin
Offline
Old 08-15-2002, 03:45 PM   #9 (permalink)
Proven Member
Region: NorCal
first i tried alcohol.. and it didnt really clean it that well until i used paint thinner.. the alcohol i used? just the typical one u use around the house.. rubbing alcohol..
1998 GS-T (Sold)
1995 GSX x2
Offline
Old 08-15-2002, 07:14 PM   #10 (permalink)
Proven Member
Reputation: RocketDSM is an unknown
Never use rubbing alcohol on anything that you really care about and will not get refinished in something else. Rubbing alcohol leaves a film over everything when it evaporates. Water does not get it off. Go to an electrical supply store and you should be able to find Isopropyl Alcohol. Not only is it stronger at cleaning, but it evaporates completely. Neat things the Navy teaches us electronic types, huh?
Offline
Old 08-15-2002, 09:23 PM   #11 (permalink)
Proven Member
Classifieds Rating: (5)
Reputation: doug is pretty helpful and trustworthydoug is pretty helpful and trustworthy
Quote:
I tried taking the sidemarker out, but that still wasn't good enough. So I removed the first three (counting from the wheel well and going forward) bolts holding on the front bumper cover. Then it's a snap getting a ratchet extension in between the bumper cover and the chassis to remove/replace that front I/C bolt.
J Doug
Offline
Old 08-16-2002, 03:49 PM   #12 (permalink)
2gTurboS
Posts: n/a
I just removed my whole front bumper and inner fender.Getting it out was cake after that.I cleaned mine Inside and out with 93 octane and Two cans of Fuel Injector cleaner its so clean inside of it now.Later Corey D
Old 08-16-2002, 04:41 PM   #13 (permalink)
Proven Member
Reputation: BatmanGSX is more helpful than not
I took mine to a shop and had them run gallons and gallons of solvents through it in the their parts washer. The did if for free so I gave the mechanic who did it $10 for his time. Whatever you do, don't use any sort of pressure on the outside. Just a hose and my thumb was bending the fins.
Offline
Old 08-16-2002, 08:50 PM   #14 (permalink)
Proven Member
If you don't have some sort of catch can on the breather hose, the intercooler and piping will be just as dirty again in a few months. I highly recommend for everyone to use some sort of method to catch the oil blowby so your piping and intercooler stay cleaner longer. I did the $3 catch can mod, which is just placing a cheap plastic fuel filter in-line with the breather hose. Doesn't catch 100% of the blowby, but it's a lot better than nothing.
In fact, I was wondering if since one filter is good, would two be better? There's not a lot of resistance in the filter-- you can blow through it very easily. Any thoughts on that?
J Doug
Offline
Old 10-25-2002, 04:53 PM   #15 (permalink)
Proven Member
Classifieds Rating: (4)
Reputation: gstspyder1998 is an unknown
Question What is the best cleaning solution when cleaning your Intercooler???
Ok, I've only cleaned my intercooler once with paint thinner and I did it in my bathroom. The fumes basically stayed in my house for a couple of days and everybody in the house got high off of it!!! Well I don't plan on doing that again but I need to clean my intercooler because I can see a lot of oil coming out from it when I was fixing my UICP. I know you can also use gasoline but that's worst than paint thinner. Has anybody use a different type of cleaning solution that does the same job as paint thinner and gasoline????
Offline
Old 10-25-2002, 05:33 PM   #16 (permalink)
Proven Member
Reputation: rubbersidedown is an unknown
gasoline heh
Offline
Old 10-25-2002, 06:47 PM   #17 (permalink)
Proven Member
boosted_91_tsi's Avatar
Region: Southeast
Classifieds Rating: (1)
Reputation: boosted_91_tsi is more helpful than not
gasoline worx best but make sure u let it dry COMPLETELY before reinstalling it. I would suggest you get a breather filter as well and then you will not have to worry about oil getting in there again.
--DannyB
Offline
Old 01-31-2003, 08:45 AM   #18 (permalink)
Proven Member
Reputation: UltraImports is an unknown
Intercooler cleaning
I'm cleaning my intercooler this weekend before I get it up and running again. I know I'm supposed to use gas...but how many times do I have to do it? Wash, Rinse, Repeat....lol
Thanks.
Offline
Old 01-31-2003, 08:48 AM   #19 (permalink)
Proven Member
Region: Mid Atlantic
Reputation: Tallen is pretty helpful and trustworthy
till the gas doesnt come out black
-Matt
Offline
Old 01-31-2003, 08:49 AM   #20 (permalink)
Proven Member
go figure...right
lol. Thanks man.
Offline
Old 01-31-2003, 09:20 AM   #21 (permalink)
DSM Wiseman
acetone has worked better for me in the past =), but gas will work fine to...
Austin
Offline
Old 01-31-2003, 10:17 AM   #22 (permalink)
Proven Member
Reputation: jbillakdsm is more helpful than not
I used rubbing alcohol (30 cents a bottle on sale) and flushed it with around 2 bottles per flush. The first flush came out real dark and the second was a lot lighter, but still noticeable. The third flush was practically clear. If you can, get something to seal off both ends so you can shake it as much as possible. I used some cut up water balloons and some zip ties for the one end and my hand for the other. I then let it dry for about an hour in front of a heater. I figured if there was any alcohol left, it wasn't really going to hurt that much.
Jake
Offline
Old 01-31-2003, 11:24 AM   #23 (permalink)
Proven Member
I'll just let it sit out and let the rest evaporate. Thanks for the helps guys. I'll tackle this tonight.
Offline
[webpage] [posts]
