Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Appearance/Interior/Exterior
Appearance/Interior/Exterior All discussions that are non-performance related; body kits, conversions, paint, lighting, alarms, car audio, washing, waxing, etc. New Members can post here.
Reply
LinkBack Thread Tools
Old 04-19-2002, 08:30 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: Atari007 is an unknown
Question Firewall holes? [Merged] drill, drilling, pass-thru, wire, gauge, power, passenger
Hey, where did you guys route your power wire through the firewall (in a 2g)?? The only place that I have really found is the steering wheel boot....
Atari007
Offline
Related Auctions
Sponsored Links
Old 04-19-2002, 08:43 AM   #2 (permalink)
Proven Member
Classifieds Rating: (1)
Reputation: 98_silvergs is an unknown
I drilled a hole on the upper part of the firewall on the drivers side. The wire went through and dropped right into the interior.
____________________________
- Ryan
Offline
Old 04-19-2002, 09:01 AM   #3 (permalink)
DSMtuners Wiseman
There is a grommet in the passenger side foot wheel that leads right through the firewall. Its where most of the internal wiring runs into the engine bay. From the engine, its under your battery tray.
-Sean Caron
Offline
Old 04-19-2002, 10:59 AM   #4 (permalink)
Proven Member
Classifieds Rating: (2)
Reputation: larryd is an unknown
anybody done this?
Offline
Old 04-19-2002, 11:36 AM   #5 (permalink)
Proven Member
oh... :)
I guess I could have looked at the post 3 or 4 down from this one eh? lol... thanx though guys!
Atari007
Offline
Old 04-19-2002, 12:23 PM   #6 (permalink)
Proven Member
haha its cool.. the post subject wouldnt make u thnik it was about the same thing, i just remembered replying to that one..
Offline
Old 07-26-2002, 12:09 PM   #7 (permalink)
Proven Member
Region: Midwest
Reputation: Dyncaus is an unknown
hole in firewall?
does anyone know if there is a pre-existing hole in the firwall of a 97 Eclipse GST that i could use to run my amp wire through, and if not then where a good place to run it would be.
Offline
Old 07-26-2002, 01:05 PM   #8 (permalink)
Proven Member
I couldnt find an existing hole so i drilled a hole on the drivers side firewall. Just be careful and make sure there are no wires in that area.
- Ryan
Offline
Old 07-26-2002, 01:08 PM   #9 (permalink)
Proven Member
Reputation: dsmnate is more helpful than not
I believe there is supposed to be a good place behind or below the battery on a 2g turbo. I it has been said that there is a grommet there where all the factory wire go through that you can use. I haven't checked this out myself yet but will be within the next week or so since my stereo is finally ready to be wired up.
-Nate
Offline
Old 07-28-2002, 09:51 PM   #10 (permalink)
Proven Member
Reputation: amhalon is an unknown
i just ran my wire a few weeks ago... there is an existing grommet on the passengers side...i just pushed my wire thru and straight up the the battery...good luck, hope it sounds good...
Offline
[posts] Reply With Quote
Old 07-31-2002, 03:16 AM   #11 (permalink)
Proven Member
Reputation: ricktsu is an unknown
yup passwenger side grommet. Save your self sow mheartache if you have 4 gauge cable and remove the battery and holding trays.
Offline
Old 08-07-2002, 02:37 PM   #12 (permalink)
Moderator
Region: Rocky Mountain
Classifieds Rating: (19)
Quote:
I have a 2 guage cable and 8 guage cable to run, will it fit through that factory grommet?
Offline
Old 08-07-2002, 02:47 PM   #13 (permalink)
Proven Member
Quote:
Why don't you just run the 2 gauge cable through and then run the 8 gauge you need off of a distribution block from the 2 gauge.
-Nate
-Nate
Offline
Old 08-07-2002, 11:29 PM   #14 (permalink)
Moderator
Quote:
-Nate
The 2 guage is for a 1200 watt RMS amp at 12.5 volts (MTX 1000d) so it needs all of the wire to itself. I just drilled a hole on the passenger side of the factory grommet and put it through there (the 8 guage). And put the 2 guage through the factory grommet after about 45 minutes or trying.
Offline
Old 08-08-2002, 07:07 AM   #15 (permalink)
Proven Member
Yeah tell me about it. I just put a 4 gauge through last night an man it was a pain in the a$$. I guess it would have been easier if I removed the battery tray but I was too stupid to do that.
-Nate
-Nate
Offline
Old 09-15-2002, 02:22 PM   #16 (permalink)
Proven Member
Reputation: Cougarct is an unknown
Need help on running wires through the firewall on a 99 eclipse rs auto
i am going to be install neons on a eclipse for a friend of mine but i need some help . could someone help me and let me know if there is a grommet or pre drilled hole for running some small gauge wire through the firewall???? the car is a 99 eclipse rs automatic.. im asking ### on other cars i have worked on had grommets for the 5 speed model,, for the clutch. so i was wondering if there is one on this car if not. whats a good place to run the wires through or drill ?? any help would be appreciated. thanks
Offline
Old 09-15-2002, 02:25 PM   #17 (permalink)
Proven Member
Region: SoCal
Classifieds Rating: (5)
Reputation: turboholic is more helpful than not
-Rubber boot of the steering column.
-Kevin.
Offline
Old 09-15-2002, 03:16 PM   #18 (permalink)
Proven Member
thanks ,, mark
Offline
Old 09-15-2002, 06:26 PM   #19 (permalink)
DSM Wiseman
dave99gst's Avatar
Classifieds Rating: (29)
ya what kevin said
Offline
Old 10-12-2002, 10:23 PM   #20 (permalink)
Proven Member
Region: Pacific Northwest
Reputation: Laser0385 is an unknown
Angry Firewall hole!?
Ok, I'm installing my sub and amp but I can't even find the hole in the firewall to thread the wire through. I have a 1G, so if someone could tell me where the hole is and how to get to it would be great. Also, my headunit is a b!tch to get out, got any suggestions, the headunit is aftermarket by the way. Thanks.
Offline
Old 10-12-2002, 10:35 PM   #21 (permalink)
DSM Wiseman
Region: Midwest
Why can't you just route it the standard way, through the rubber steering boot??
Eric Gash
Offline
Old 10-12-2002, 11:45 PM   #22 (permalink)
Proven Member
How do you do that?
Offline
Old 10-13-2002, 08:52 AM   #23 (permalink)
DSM Wiseman
Region: Midwest
Follow the steering column down to the firewall. There will be a black rubber boot on the FW that the column goes through. Just cut a slit in this boot and run your cable through.
Eric Gash
