tranny probs???
Rick20834
Oct 21, 2009
Chicopee, Massachusetts
hey ny tranny is making clunking noise and i dont know why i fixed the throwout bearing and its stilling doing it. when i drive it in 1st gear and i drive with high rpms its loosing its torque any ideas??
I would definitely do a fluid change to start and use a good syncromesh or royal purple, ect... Then i would check and see if you are still having probs with the noise and loss of torque. I too had the same problem a while back and it ended up that my 1st and 5th gears were complete shot along with the shaft. So $450 and new tranny rebuild later and im back to kikin @ss on the roads. LOL I hope this helps. :)
I agree that you need to check and change the fluid and if your loosing power you may need to replace your clutch.
