MNGSX
- 2,533
- 25
- Mar 30, 2003
Bloomington,
Minnesota
Anyone installed these?
If so how much
There are three mounting locations for the links.
The instructions say to use the middle position as a rule of thumb for a starting point.
I'm considering just using the tightest setting right off the bat and trying that first. Did you find that there was a big difference in swaybar preload across the range of the three mounts or was it a subtle difference?
I'm also going to do the ES suspension bushings some time this spring. I like the 1 piece design and that they are'nt quite as hard as some of the others. This leads me to believe they will last longer as a harder bushing is more likely to crack and a one piece design is stronger. The only drawback is installation for those w/o access to a press..
As for making the old bushing removal easy it is also called a 20 ton shop press at work.
If so how much
