Boston_Talon
- Mar 2, 2003
I just failed the state inspection because the tie rod is loose on the passenger side. I was told I need the inner tie rod (from the boot to the nut) replaced and should do the outer (nut to the wheel) at the same time. I was quoted $349 for it and walked out, want to check costs first. I have read a number of posts, and have info on replacing the tie rod ends, but not much on the inner tie rod. I have read that some use a pickle fork and some ppl just tap it out with a hammer. Any tips for a poor unemployed newbie would help. I'm just not sure what I'm gonna get into when I pull the boot back.
Thanks
Marc
[email protected]
Thanks
Marc
[email protected]
