Dr. Design
- Aug 27, 2002
California
Just FYI,
We have noticed that there are a lot of companies out there saying that certain products stiffen the chassis. In reality they do no such thing. Most people think that by adding an aftermarket sway bay it will stiffen the chassis. Wrong! This is kind of an extreme example but you will get the basic idea. The sway bar will reduce the body from rolling on the frame and suspension. Picture the car from the rear. Pretend that there is a ball between the suspension and the body that allows for the body to pivot off of the ball. What the sway bar will do is reduce the amount of pivot that the body has on that ball. The sway bar does exactly what it is supposed to do. One thing it will not do is stiffen the chassis. ONLY chassis stiffeners will do that. So what we have here is the chassis secured on the suspension with body roll.
Question? What is keeping the chassis from twisting? A sway bar, springs, and shocks are not the answer to superior handling. Even if you use stiffer springs, stronger shocks, or a huge sway bar, what is keeping the corners of the car from moving at different levels (aka twisting)? When the chassis twist it waste energy and takes away performance from your suspension. If anything it is even more apparent that the car is twisting. If you add a chassis kit or a roll cage to the car it will keep the chassis neutral and all four corners in sync with each other. As a result this will allow the suspension to do what is supposed to do. The 1st law of physics states that, "An object at rest or moving at constant velocity will continue to do so unless acted upon by an external force". The CSK-C IS THAT EXTERNAL FORCE!
An example can be seen here.
http://www.dsmtalk.com/forums/showt...&threadid=61436
Thank you,
Thank you,
