CowPimp
- 602
- 3
- Aug 4, 2002
Silver Spring,
Maryland
My vehicle is a 96 TSi AWD with Tokico shocks and Eibach prokit springs (1.3" drop).
I recently realized that my rear camber is off. The bottoms of my wheels are definitely staggered outwards a little, and tire wear is slightly uneven (Thankfully it's not terrible). So, I am definitely in the market for a rear camber kit. However, my front wheels actually look pretty good in terms of tire wear and vertical stance (I think they are ever so slightly off).
So, my questions are as follows:
From what I have discovered by searching, front camber kits are needed less often than rears. Do you guys think it is necessary that I get a front camber kit as well, or might an alignment adjustment do the job?
Will the camber adjustment fix my alignment, or should my alignment be done at the same time?
I already know 4-wheel alignment should be in the neighborhood of $60.
How much money am I looking at for the installation of these kits and the adjustment?
