jim97gst
- 482
- 3
- Aug 2, 2002
Bethel Park,
Pennsylvania
OK, I'm getting ready to make a coilover decision. I have a 97 GST. I'd like to start this out by saying that I don't know much about suspension tuning. I am taking a suspension class right now, so when I get whatever I'm getting, I'll be able to do the alignment myself, make adjustments and do some experimenting. I know what all the basic suspension parts are and what they do, but as far how to make them do what I want the car to do, I have very limited knowledge. Although I have read this whole thing: http://www.dsm.org/menu.epl?item=352, so I'm an expert now, right
? Here are my goals for the suspension:
1. Pretty comfortable- the car is a semi-daily driver (2-3 times per week to work+errands), and I don't want the ride to become so harsh that I dread driving the car on the street.
2. Performance - capable of being a pretty competitive autocross setup. I autocross about once per month in STX. I'm not really hard core about it, but I may be more so with a new suspension. I'm mainly there to have fun, but it would be more fun if I were winning. I may also try and do some open track days with the car eventually.
3. Ease of use- I've already said I don't know much about suspension tuning. I want someone else to do most of the up front work. Since I've never done a suspension upgrade, I don't really feel comfortable picking out a bunch of different pieces and putting them together. While I understand the theory, I definitely need to play with a suspension before I start to really understand how they work and how to tune them for my needs.
4. Cost- I'm willing to spend some money to get something I'll be happy with to meet goals 1-3. But I'm not going to go crazy either. The JICs are probably as expensive as I would ever go. So please don't suggest custom coilovers with remote reservoir bilsteins, etc...
Here is what I think I've narrowed my choices down to, from 1st to last, with pros and cons as I see them. I am open to other suggestions though.
Tein Flex
spring rates:10FR/6R
pros: I've heard nothing put praise all around. Everyone seems happy with the ride quality for a daily driver. Seems to have a good reputation for quality. Lots of adjustments. Reasonable price. Everything is matched and designed to work together. Is designed to be a good compromise between street/track. Sounds like a winner for my goals.
cons: Hasn't been around terribly long (at least in the US), so no one can give any really long term experience (like how long the dampers last and what kind of trouble/cost I have to go through to get them serviced). Doesn't seem to be recommended by anyone that does any sanctioned/competitive racing. Stock spring rates maybe a little soft in the rear to get the car to rotate? I guess I could buy a stiffer set of springs later, but apparently only from Tein. Plus the dampers are adjustable.
JIC FLTA2
spring rate: 9FR/7R (or whatever I want)
pros: I've heard nothing but praise for the performance. Seems to have a good reputation for quality. Lots of adjustments. Everything is matched and designed to work together. RRE uses these for their own race cars.
cons: Three most common adjectives I hear used to describe the ride are stiff, STIFF, and STIFF!!!. Although I don't totally understand why because the spring rates are so similar to the flex - I guess the damper valving is that much more harsh? $$$ - although I have seen them lately for as little $1500, so I'm actually considering them. Seems to have a reputation for being difficult to get setup just right. RRE charges $100 for an "initial setup" to save you a days work. I don't mind the time, but I worry I couldn't get it setup right even with several days. I guess this is true for all aftermarket suspensions, but I haven't heard it about the flex - but maybe this goes back to nobody really serious about racing using them.
GC/Koni
spring rate:whatever I want
pros: The main reason I'm really considering these is because DG as well as others who autocross competitively use and recommend them. http://www.dsmtalk.com/forums/showthread.php?s=&threadid=98687 and http://www.dsmtuners.com/forums/showthread.php?s=&threadid=34084 Although DG admits he has no experience with Tein or JIC. I can choose my own spring rates, but this is almost a con for me because I don't know what I'm doing. I've read several good reviews of them in general. More easily serviceable compared to Teins and JICs.
cons: Not really designed from the start to work together, although several others have done this combination and are happy. I have to buy stuff from 3 different companies (I would get some upper mounts if I choose this suspension) so if something goes wrong with one part, there maybe fingers pointing in 3 different directions. I've heard mixed reviews on the ride quality. I've heard of more than one person that went from this setup to a Tein flex or ss and found there to be an improvement. While they may have been doing something wrong, I'm sure I'm just as capable of making the same mistakes.
So there's my compilation of everything I've read on these suspensions. I'm kinda waiting for SCC to put The Tein flex on their project Civic and see what they think of them. Please give me some opinions. I would mainly like to hear from people who have owned or ridden in DSMs equipped with 1 or more of these choices (or something very similar). Please don't give any responses like "Tein ownz you!". I'd like to see something informative that I haven't read yet or thought of.
Also, I'm in Tucson, so if anybody in Tucson or Phoenix wants to give me a ride in their DSM with one of these suspensions, that would be awesome.
Thanks for reading.
? Here are my goals for the suspension:1. Pretty comfortable- the car is a semi-daily driver (2-3 times per week to work+errands), and I don't want the ride to become so harsh that I dread driving the car on the street.
Tein Flex
JIC FLTA2
GC/Koni
Thanks for reading.
