widest rim for 96 talon
prplppleatr
Aug 8, 2002
jus wonderin whats the widest rim you can put on a 96 talon tsi awd, right now i have 17 x 7 and it jus doesent look wide enough, thanks
You can't answer that without knowing an offset. I know I can run 17x10's if I have a+12mm offset and it won't rub. And speaking of that, are you talking about the rim rubbing or the tire? Again you can't say for certain a wheel/tire combo will rub until you know the rim offset and width, and the tire size.
For instance I run 235/40/17 tires on 17x7.5 +35mm offset rims. No rubbing. When racing I run 245/45/16 tires on 16x8 +32 offset rims. No rubbing except on the fender inner lip at full bump.
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
