Skunk2's not low enough?
240GTR
30
Sep 12, 2003
Yourtown, Montana
Just installed a set of Tokico Ill. and a set of Skunk2 C/O's, and they are on the lowest setting, and they still look stock height, I guess it needs to settle. Has anyone ever done this setup, and had it settle a good bit?
Eric
Are you sure you installed them correctly?, also what iam thinking you need shorter shocks for coilovers, if you get for example stockies. u can go low on rear if you go to the end, but if you go lower in front. it will be same as sportlines springs height. (werid)
so i think we need shorter shocks. for coils.
