Shocks or Struts. Whats the difference.
wibblersnatch
512
Sep 14, 2002
Fleming, Ohio
I was told I need some new struts. I thought they were shocks? Whats the diff? And where can I find a decently priced set. I'm planning on buying an Eibach pro - kit if this info helps.
Different name, same thing. "Struts" mostly comes from the wacky world of Fearsome Struts, but it isn't entirely wrong in the DSM galaxy, as they are used as _part_ of the suspension linkages, not wholly as a member like McPherson. Usually a "shock" does nothing but dampen suspension movement, while not contributing to the structure of the assembly- you could drive a cars that uses "shocks" without them (but no, not very far, fast, or well), whereas if you took the "struts" out of a car so equipped, you couldn't.
Other than my usual "eBay" reply, I'd not know where to send you for a kit.
